gui not showing correctly at resolution 640x480
Started by knolle, September 12, 2008, 08:29:16 PM
knolle
the bottom part is left out unable to scroll down
regards:
knolle
Thanks. I see the problem. I will get it resolved asap.
Until I get this problem with InstallHelper resolved, users should just hit enter to get past that dialog. Everything will work fine.
You can also uncheck the 'Show the startup options' section in the installer. This will skip that part of the install process.
Note that at 800x600 the dialog in question fits (barely).
knolle
i hope this clarify that i meant the hole gui not just the dialogues.
regards:
knolle
Hmm, interesting. I thought had it show up ok when I tested once in 640x480. Try to resize the window, then maximize it.. if you haven't already. I'll do some more testing and get it working at 640x480 .. clearly the initialize positions of the windows are totally screwed ;).
Thanks.
One more note... Process Lasso saves its window positions, so its possible that what you see may be the result of it trying to restore the old child window positions that were saved at a higher resolution. I'll add some safety checks in case is the problem. You may want to try resetting the window position (the windowdata value of the HKCU\Software\ProcessLasso registry key). An uninstall should remove this setting.
